Photosupreme batch add item, Macro selection
artphotopro
Post by artphotopro » 10 Apr 18 10:24
Hello All,
Has any one else run in to these problems,
1, batch - Add item window too small
2, filter by macro command - contains value, drop down not selectable.
I have attached a couple of images, Not sure if this is a problem I have created some how or just never used these 2 before and its a bug
Regards
Chris
batch add item.jpg (332.16 KiB) Viewed 1543 times
gcorbin
Re: Photosupreme batch add item, Macro selection
Post by gcorbin » 16 Apr 18 20:53
Yes, I have the same issue.
1 The batch Add Item list is too narrow as is the Stored Batches drop down. This is probably the same issue as the “Import profile dialog truncated” item at
viewtopic.php?f=57&t=26805
There seems to be an issue with drop down widths with some video setups.
2 The filter by macro command is also not working for me. I can drop down the Contains value list but cannot select any other value such as Equals.
I am running 4.0.1.1201 64 bit on Windows 10.
artphotopro
Post by artphotopro » 19 Apr 18 9:21
Hello PS support,
If you require any extra info or system info please contact me.
Regards
Chris
Post by Hert » 20 Apr 18 8:18
Chris, did you receive my email? Thank you
