Import profile dialog truncated.
dickl
Post by dickl » 16 Mar 18 20:00
For some reason, when I try to select an import profile, the dialog drops down and is too narrow to show the profile names... See attached... I tried uninstalling and reinstalling PS4, but it came up with the same result. Windows 10 64 ver 16299-309, Intel Core 2, AMD Radeon R7 240 display. I am using the same software on my Dell XPS 13 9360 laptop, and it works fine there. Any ideas?
Import Profile Dialog.PNG (34.14 KiB) Viewed 2027 times
Kevin_C
Re: Import profile dialog truncated.
Post by Kevin_C » 17 Mar 18 20:37
Same here, noticed it this afternoon - Windows 10, PSu version 4.0.1.1125 (64bit) - I don't recall this whilst running the previous version. Not a big deal for me, but annoying :-)
Kevin
gcorbin
Post by gcorbin » 23 Mar 18 11:03
I get the same thing on Windows 10, PSu version 4.0.1.1125 (64bit). It has been in at least the last couple of releases but I am sure it wasn't in the first couple of releases (4.0.0.985 onwards). Again, it is a minor glitch so I haven't bothered reporting it.
Post by jstartin » 23 Mar 18 11:44
I am also using build 1125 and Windows 10 and do NOT see this. Here the dialog is (just) wide enough to show all of the "Load profile from file..." line. I wonder whether this has something to do with screen resolution and scaling - I am on 2560 x 1440 and 125%. I suggest it should be reported on Mantis, with all the details of the graphics settings, so that Hert will know to look into it.
Kevin_C
Post by Kevin_C » 24 Apr 18 18:46
For info this is not a problem for me now with the latest update.
gcorbin
Post by gcorbin » 24 Apr 18 22:52
This is now fixed for me in version 4.1.0.1402. Thanks Hert. Great update.
dickl
Post by dickl » 25 Apr 18 14:42
All fixed here too. Thanks Hert.
