10-bit color depth support
nesys
Post by nesys » 10 Jan 18 1:46
Hi folks,
do you know if PSu is supporting 10-bit color depth, like CS6?
thank you
Andrea
Re: 10-bit color depth support
Post by Hert » 10 Jan 18 12:32
Hi Andrea,
I assume you mean a 10bit color depth monitor? PSU will write to the monitor in 8bit. But that shouldn't be a problem for a 10 bit monitor. AFAIK the GPU is more what you should be looking for to support 10bit
nesys
Post by nesys » 10 Jan 18 21:44
thanks for your answer.
well, in a word ... banding :) but not only.
https://www.youtube.com/watch?v=bKjSox0uwnk
On the other hand, all the chain needs to be consistent ... GPU is a part of it, and also software is a part of it. If you have monitor, GPU, OS, but missing software, you are not able to see your images with 10 bit color depth.
Any chance PSU will support this sooner or later?
Andrea
Post by Hert » 10 Jan 18 22:22
Hi Andrea, thank you for the link.
PSU will always try to support formats used by a substantial part of its user base.
nesys
Post by nesys » 20 Jan 18 13:03
hehehe tricky answer :)
all is around the word "substantial" ... do we need to have a POLL for it?
Andrea
