Hide Photo Supreme
MikeNaylor
Hide Photo Supreme
Post by MikeNaylor » 21 Dec 17 19:54
The Menu bar command Photo Supreme -> Hide Photo Supreme does not work when there is a spinning ball. This is particularly annoying when performing a full compact or backup, because these processes can take a long time to execute, making it impossible to access the Desktop.
Maybe this is 'just' a Mac thing, but does anyone else experience this?
Re: Hide Photo Supreme
Post by Stephen » 27 Dec 17 12:54
I cannot remember, but have you just tried selecting another application?
MikeNaylor
Post by MikeNaylor » 28 Dec 17 15:52
Yes I can do that, but if PSu is using the full width and height of my display, I can't hide PSu to access the Desktop. Its a bad habit, but I do tend to leave things directly on the Desktop.
Post by tstoddard » 28 Dec 17 21:52
Mike,
I'm not a MAC user so I'm curious, isn't there a shortcut you can use to reach the desktop on a MAC? When I google it, several solutions come up. One suggests that you can specify a keyboard shortcut of your own. If you do keep a lot on your desktop, I would think it would be useful to have such a shortcut set up.
MikeNaylor
Post by MikeNaylor » 28 Dec 17 22:17
Thanks Tom. I'm not a shortcut fan, so I hadn't thought of that. It turns out there are several, but he easiest one for me is simply F11.
Post by Stephen » 29 Dec 17 17:01
Under Mac, the F9 key will show all open windows on one page, which you can then select. Perhaps that helps?
