Portfolios + collections
Le_Lion_07
Post by Le_Lion_07 » 13 Nov 17 14:34
Hello from France...
1. When I rename a collection or
2. when I move a collection (up or down) in a portfolio,
the photos in this collection are out of sync.
Is it a usual behaviour ? If it is, why ? There is nothing to synchronise because portfolios/collections are part of the catalog, not of metadata.
Photographies
L'importance du regard...
Re: Portfolios + collections
Post by Hert » 13 Nov 17 15:54
Could it be that you have ICS writing switched ON? In that case the portfolio collection will also be written to the metadata...in the ICS schema
Le_Lion_07
Post by Le_Lion_07 » 13 Nov 17 16:11
Hi Hert...
Not at all, the ICs schema option is switched off, both for reading and writing.
Photographies
Le_Lion_07
Post by Le_Lion_07 » 15 Nov 17 17:49
Same thing if I delete a collection, the photos in this collection are out-of-sync.
Photographies
LifeIsLong
Post by LifeIsLong » 16 Nov 17 11:48
I too have been having a lot of cases where changing portfolios triggers a mass re-synch. I, however, do have ICS written to metadata so changing portfolios makes sense to me.
What does not make sense to me are when re-synchs are triggered:
1. on all photos already in a portfolio when I import new pictures into it.
2. On photos that are added/removed from the image basket.
So, might be a slightly different symptom, but I think it relates: mass re-synch's are being triggered at odd times. If I import new photos, thousands of existing photos that have not changed claim to be out of synch.
Le_Lion_07
Post by Le_Lion_07 » 29 Nov 17 17:30
On my computer, add or remove one or several pics to/from a collection have no effect on sync (the pics stay in sync). But any other action with a collection : move it up or down in the structure, rename it, even delete it and the pics are out of sync. This has no sense because, as I wrote, the ICS schema option is switched off, both for reading and writing.
Photographies
