I’m doing some filing and using templates which have not been used for some time.
One of them inserts the field “T EventName” which I believe changed to “%EventName” some time back. However, when I open the template, make the changes and save it, the first use (import of images) works correctly. After that it resorts to the old version.
Does anybody know please?
Rename rules when importing - templates not saving
Re: Rename rules when importing - templates not saving
it seems like the mistake is still exiting or being there again
viewtopic.php?f=57&t=27483
T eventname does not work
% Eventname works, but only once until the next call, then it is again T Eventname and also uses the term Eventname instead of the variable's content
Ralf
(Excuse my english)
(Excuse my english)
