Search by processing software
Larry56
Post by Larry56 » 05 Feb 17 17:48
Is there a way to search and display images processed by specific converters? Ie, if I want to find all I processed in Lightroom or DXo or Capture One or ??. I tried just a search but that resulted in images show before I even had some of the software.
Re: Search by processing software
Post by weidmic » 05 Feb 17 18:35
Yes, you can...
First of all - you need to make sure that PSU does not overwrite the software tag...
http://www.senoiaphoto.com/psu
see registry twaeks
you can then use filter by macro commands, see attached screenshot
I use the software tag also in my custom thumbs info (in this case it schows cam - which means it is untouched)
Hope that helps,
Larry56
Post by Larry56 » 06 Feb 17 19:27
Thank you Michael but I think additional training. How do I add the registry tweak? It appears it's not already in the registry? Also, If I do an update of PSu or install a new version will it overwrite the registry tweak?
Post by weidmic » 06 Feb 17 20:45
Within PSU call the scripter - copy and paste that code and let it run... /restart PSU
Usually the tweak will not be overwritten when you do an update.
However, since these are only tweaks and not officially supported it is always possible that at some point the tweak is not supported anymore.
WriteToRegistry ('', 'UpdateSoftwareTag', 0)
Hope that makes sense...
Larry56
Post by Larry56 » 06 Feb 17 22:54
Thank you.
