Stubborn description date
Post by Stephen » 15 Jul 16 12:30
I cannot seem to lastingly change the description date of an image, as it always reverts to the current one, which is 30 July. It should be 29 July as is the image date.
PSu appears to be using this field to show the order of images when sorted by Photo Date. It is therefore placed with other images from July 30, rather than being in its series from July 29.
Update:
Further down in the Details pane I found that the photo date and digitized date and both been changed, so I was able to change them back. I had not suspected this to have been possible because I had renamed the file with a format to pick the date and time of the original photo.
Problem solved however.
