force building of missing thumbs and previews?
Re: force building of missing thumbs and previews?
Post by Stephen » 17 Aug 18 17:35
I've had this problem for a long time. 82 missing thumbs are always found and rebuilt, but they do not display. Then if I repeat the process the same happens again.
I cannot find how to filter "without thumbnails", but perhaps that is only available with version 4?
User avatar
Post by G8DHE » 18 Aug 18 10:59
Yes probably only on 4+ but click the filter Icon, then in the dropdown for the filter itself;
Post by Stephen » 18 Aug 18 14:52
Thanks, so it must be a version 4 feature. I'm still using version 3.
MelG
Post by MelG » 12 Jan 19 1:15
I'm using a trial of version 4.
I can not get any of my .DNG files to show thumbnails or previews. Is this a known issue, or (more likely) am I missing something? I have even added .DNG to the "File Handling" list. This is surprising to me because even Affinity Photo files (.AFPHOTO) show with no problem. I have also tried "Build Missing Thumbnails and Previews".
Help please. :?
Post by weidmic » 12 Jan 19 13:24
MelG,
did you check if the DNG file has the preview embedded?
When you create a DNG you need to make sure you embed the preview!
AFAIK, many of the native DNG do not have a DNG embedded...
Cheers, Michael
MelG
Post by MelG » 13 Jan 19 19:43
Thanks for the suggestion, Michael.
I do not know how to check if the preview is embedded. It does show on my system file preview (MacOS) and in the directory.
