Lightroom develop/keywords in PS3
Larry56
Post by Larry56 » 24 Mar 15 20:07
I must have a setting wrong or a wrong expectation for PS3 in Windows 7.
I developed some Canon RAW files in Lightroom 5. They included cropping and color, etc adjustments. I also added some keywords and IPTC information. However, when I went to PS those changes are reflected.
Should they be showing the cropped, keywords, IPTC metadata in PS?
DirkS
Re: Lightroom develop/keywords in PS3
Post by DirkS » 24 Mar 15 22:28
Did you save the metadata in LR?
Larry56
Post by Larry56 » 24 Mar 15 22:48
duhhhh. :oops:
Larry56
Post by Larry56 » 25 Mar 15 16:59
Is there a way to see in PS that the RAW image being displayed has been developed in Lightroom?
Post by weidmic » 25 Mar 15 20:59
One way would be to use the custom thumbs info.
This is the code for the second line that I use (its the part //add software ID)
%ImageFileSizeShort  %code
var
  ASoftware: WideString;
begin
  ASoftware := '%xmp:tiff:Software';
  result := ToWideString('');
         // add software ID
              if WideTextPos('Capture', ASoftware) = 1 then
                result := result + '<FONT color="#888888 ">NX2</font>'
              else if WideTextPos('Adobe Photoshop Lightroom', ASoftware) <> 0 then
                result := result + '<FONT color="#888888 ">LR</font>'
              else if WideTextPos('Photoshop', ASoftware) <> 0 then
                result := result + '<FONT color="#888888 ">CS4</font>'
	      else if WideTextPos('Adobe DNG', ASoftware) <> 0 then
                result := result + '<FONT color="#888888 ">ADC</font>'
	      else if WideTextPos('IDimagerSU', ASoftware) <> 0 then
                result := result + '<FONT color="#888888 ">PSU</font>'
              else if WideTextPos('Bibble', ASoftware) <> 0 then
                result := result + '<FONT color="#888888 ">BIB</font>'
              else if WideTextPos('Ver.1', ASoftware) = 1 then
                result := result + '<FONT color="#888888 ">CAM</font>'
              else if WideTextPos('http://www.idimager.com', ASoftware) = 1 then
                result := result + '<FONT color="#888888">IDI</font>'
              else
                result := result + '<FONT color="#888888 ">-?-</font> ';
              if ImageItem.IsRaw then
                result := result + '</font> <FONT color="#888888">' + WideUpperCase('%FileExtension') + '</font>'
              else
                result := result + '</font> <FONT color="#888888">' + WideUpperCase('%FileExtension') + '</font>';
              // add GPS indicator
              //if ImageItem.HasGPS then
                //result := result + '<FONT color="#3300FF"> GPS</font>';
end;
%/code %GPSExists<a href="event:ShowGEOTag"><img size="22" pathcolor="#4080C0" path="M 370.498,312.759 C 370.498,327.010 365.378,339.176 355.137,349.255 L 355.137,349.255 C 344.896,359.335 332.632,364.375 318.345,364.375 L 318.345,364.375 C 304.058,364.375 291.812,359.416 281.606,349.497 L 281.606,349.497 C 271.294,339.507 266.138,327.386 266.138,313.135 L 266.138,313.135 C 266.138,298.883 271.294,286.745 281.606,276.719 L 281.606,276.719 C 291.812,266.800 304.058,261.841 318.345,261.841 L 318.345,261.841 C 332.632,261.841 344.860,266.729 355.029,276.504 L 355.029,276.504 C 365.342,286.423 370.498,298.507 370.498,312.759 L 370.498,312.759 Z M 367.759,312.437 C 367.759,299.152 362.853,287.765 353.042,278.276 L 353.042,278.276 C 343.302,268.895 331.772,264.204 318.452,264.204 L 318.452,264.204 L 313.081,275.215 L 318.936,276.396 L 323.501,271.831 L 331.558,272.368 L 333.169,276.665 L 328.335,281.499 L 328.335,284.399 L 331.343,284.990 L 332.739,282.734 L 338.057,279.404 L 337.896,281.660 L 339.883,285.098 L 337.520,287.568 L 339.023,289.019 L 335.479,289.233 L 336.929,292.134 L 329.248,295.786 L 330.430,300.137 L 328.013,300.137 L 326.938,295.840 L 321.299,295.732 L 320.278,297.397 L 317.969,296.323 L 314.209,300.083 L 317.217,303.682 L 317.109,307.656 L 320.278,310.020 L 338.755,312.114 L 344.609,316.250 L 343.911,326.509 L 331.182,339.238 C 330.358,340.062 329.552,342.354 328.765,346.113 L 328.765,346.113 C 328.013,349.658 327.744,352.183 327.959,353.687 L 327.959,353.687 L 326.025,355.889 C 324.521,352.917 322.570,348.351 320.171,342.192 L 320.171,342.192 C 319.598,340.080 319.097,337.394 318.667,334.136 L 318.667,334.136 C 318.345,331.450 318.022,328.747 317.700,326.025 L 317.700,326.025 L 309.644,318.936 L 316.787,310.503 L 313.833,306.260 C 309.285,305.329 306.331,304.496 304.971,303.762 L 304.971,303.762 C 303.610,303.028 301.265,300.978 297.935,297.612 L 297.935,297.612 L 300.728,303.037 L 298.848,303.843 L 294.497,295.679 L 295.356,288.052 L 294.014,282.681 L 289.824,278.599 L 286.763,277.847 L 284.077,279.727 L 281.123,280.479 C 272.995,289.860 268.931,300.638 268.931,312.813 L 268.931,312.813 C 268.931,326.419 273.800,337.967 283.540,347.456 L 283.540,347.456 C 293.172,356.838 304.810,361.528 318.452,361.528 L 318.452,361.528 C 332.095,361.528 343.723,356.748 353.337,347.188 L 353.337,347.188 C 362.952,337.627 367.759,326.043 367.759,312.437 L 367.759,312.437 Z "/></a>%GPSExists %code
begin
  result := '%xmp:crs:HasCrop';
  result := StrTran(result, 'True', '<FONT color="#04B404">CRP</font>');
  result := StrTran(result, 'False', '');
end;
%/code
Larry56
Post by Larry56 » 26 Mar 15 6:02
Thanks Michael but I'm having a little trouble figuring out your code.
As I read it, the code reads from xmp:tiff to determine the program used to develop the RAW file and then based on that displays the program name. I'm not able to get the correct display results though. I use DxO and Lightroom for developing but I also have Corel Paint Shop, Lightroom, Dxo, Quicktime, and Photoshop on my tool bar. Does the layout affect how the code determines what's to be displayed?
While I can get some to display LR none display DXO (I tried editing one of your else lines).
Any thoughts why it doesn't display correctly?
Thanks.
Post by Hert » 26 Mar 15 8:11
Using software will work to know which software last wrote the metadata. To determine if an image has been edited with Lightroom or ACR (in other words: the CRS schema exists) use the Thumb Custom fragment below. It also shows you an indicator when a DxO DOP file exists:
%code
var
  AXmp: TXMP;
  AParam: TMacroParam;
begin
  result := '';
  AXmp := TXMP.Create(False);
  AXmp.CleanRead := True;
  AXmp.Load(ImageItem.XMPFileName, ImageItem.ExifFileName, False);
  AParam := AXmp.XMPDesign.FindID('crs', False);
  if Assigned(AParam) then
    result := result + iif(result='', '', ' ') + 'Lr';
  if WideFileExists(ImageItem.FileName + '.dop') then
    result := result + iif(result='', '', ' ') + 'DxO';
  AXmp.Free;
end;
%/code
Post by Mike Buckley » 26 Mar 15 11:34
You also have the option of displaying this information in the Details panel. To do that, add a new custom field defined as %exif:Software.
DirkS
Post by DirkS » 26 Mar 15 19:28
Mike Buckley wrote:You also have the option of displaying this information in the Details panel. To do that, add a new custom field defined as %exif:Software.
I assume you mean the Info Panel.
Post by weidmic » 26 Mar 15 20:40
Hert,
since I use the tweak that prevents PSU not to update the software tag -it works for me...
However, the script you provided seems more reliable!
Post by weidmic » 26 Mar 15 20:47
How can I make my script that it displays "LR" at the very same position using your script?
Post by Mike Buckley » 26 Mar 15 21:50
Yes. Thank you for catching my mistake.
Post by Hert » 27 Mar 15 8:16
weidmic wrote:How can I make my script that it displays "LR" at the very same position using your script?
var
  AXmp: TXMP;
  ACRSParam: TMacroParam;
begin
  ACRSParam := AXmp.XMPDesign.FindID('crs', False);
         // add software ID
         // add software ID
              result := result + '<FONT color="#888888">'
                result := result + 'NX2'
                result := result + 'LR'
                result := result + 'CS4'
                result := result + 'ADC'
                result := result + 'PSU'
                result := result + 'BIB'
                result := result + 'CAM'
                result := result + 'IDI'
              else
                result := result + '-?-';
              if Assigned(ACRSParam) then
                result := result + '/crs';
              result := result + '</FONT> ';
              else
end;
begin
end;
AXmp.Free;
%/code
Post by vlad » 27 Mar 15 13:22
Custom fields are also displayed in the Details panel, so that wasn't really a mistake (but rather incomplete info).
Post by Mike Buckley » 27 Mar 15 13:27
vlad wrote:Custom fields are also displayed in the Details panel, so that wasn't really a mistake (but rather incomplete info).
Considering that intent is at the heart of the matter, I am the only person qualified to confirm that it was actually both. :mrgreen:
