Scanned Tiffs won't redate with PS v3
fsalveson
Post by fsalveson » 14 Dec 14 23:52
My old photos were scanned to tiffs. I had no problem re-dating the photos before updating to PS v3 (currently 3.0.2.2060 64 bits). However, using the current version of PS, the dates won't change. I've tried both Shift-Ctrl-D approach as well as trying to make changes using the details panel. I have no difficulty with jpegs, even of the same photo when converted using PS. I've also experimented with "Convert data to XMP" first, as well as Ctrl-Alt-S and Ctrl-S. Attached is a copy of my Shift-Ctrl-D screen.
Redate tiffs.PNG (71.29 KiB) Viewed 1356 times
Re: Scanned Tiffs won't redate with PS v3
Post by Hert » 15 Dec 14 10:18
Nothing changed in V3 with regard to redating. If you already checked the obvious (file read only, etc) and you think that you've found a bug then you can log this in Mantis; http://forum.idimager.com/viewtopic.php?f=57&t=18353 Also include a (link to a) sample file there so the issue can be reproduced.
