The Offset parameter doesn't perform as described in the QuickStart Macros document and I don't know whether the document or the performance is wrong.
The document provides the example of an offset value of zero that will return the value of 1. The Image Number dialog menu doesn't allow the use of zero; it automatically changes the value to 1. Using the manual text method to configure the offset value does allow inputting a value of zero.
Whether using the Image Number dialog menu or the manual text method to configure the offset value, the Rename dialog menu reports that the offset value will be increased as described in QuickStart Macros. However, once the file is renamed, the offset value is not increased.
Once Hert explains whether the QuickStart Macro document or the current behavior is correct, perhaps someone who enjoys reporting stuff in Mantis will do so.
