How to save in Original Size for ARW files
surfbum
Post by surfbum » 26 Mar 14 2:20
How do I save a photo edited with Film Noir in it's original size?
For example, in the screen shot below you can see that the original file is 54782x3648 however the largest size I can save it in is 1616x1080.
Mahalo.
Screen Shot 2014-03-25 at 6.18.34 PM.png (615.87 KiB) Viewed 3251 times
andy@damroundup.com
Re: How to save in Original Size for ARW files
Post by andy@damroundup.com » 12 Apr 14 15:10
My guess is the software is using the built in preview for the RAW for its view and edits and this must be setup within the RAW files as a 1616x1080 file... just a guess.... perhaps you can use your RAW editor to ensure a full size preview is embedded and then try it again?
