New feature in latest update
HCS
Post by HCS » 19 Feb 14 22:13
I'm new to the forum and rather new to PSU.
I updated to the latest release and found the release notes in another thread. One of the improvements is "Added support for CaptureOne .cos sidecar files".
What does this entail? Is it picking up metadata from Capture One? Or also the versions? What about the preview based on the recipe in CO?
Re: New feature in latest update
Post by Hert » 20 Feb 14 14:12
It means that the sidecar files will be kept together with your image files, so when you move/delete/rename files then the sidecar files will mirror the changes.
I Assume that C1 is writing its metadata in the standard XMP or IPTC format in the image file. That will then be read by PSU
The content of the sidecar files is proprietary to CaptureOne.
HCS
Post by HCS » 21 Feb 14 19:16
Thanks for the reply.
IDimager wrote:It means that the sidecar files will be kept together with your image files, so when you move/delete/rename files then the sidecar files will mirror the changes.
The .cos files are in a sub-directory in the image directory. Is that taken into account?
It does, but not for RAW files.
I understand, but it would be nice if one could specify an external renderer for the thumbnails as well.
