Trial Version?
InTheFlow
Trial Version?
Post by InTheFlow » 13 Jan 14 3:48
I know this is an inexpensive program but will you be offering a trial version? Before purchase, I'd like to compare how it works to some of the free solutions I've used.
Re: Trial Version?
Post by Hert » 13 Jan 14 13:07
Hi, there's no trial version available.
InTheFlow
Re: Trial Version?
Post by InTheFlow » 19 Jan 14 22:03
Thank you for your response.
The feature that I would most like is the ability to be able to select a picture(s) within Windows Explorer, right click and have an option to re-size with IDsizer. It could open in the background, do the work and I could just hop over to the folder where they were dropped off and do whatever I need to with them.
Does it already do that? If it doesn't and you would add that, I will happily purchase a copy.
Re: Trial Version?
Post by Hert » 19 Jan 14 23:11
Hi, IDsizer is an application that is ran separately. It doesn't embed in Windows Explorer.
andy@damroundup.com
Re: Trial Version?
Post by andy@damroundup.com » 22 Jan 14 16:18
[edited by Hert; removed link to other software]
perhaps Hert will add explorer tie-ins in a future release.
