how can visualize all the image without these labels?
mantras
Post by mantras » 14 Oct 13 11:12
Hi
i have lots of photos with the labels Black and white and many others with label beautiful and other woman
how can i visualize all the photos without the labels black and white,beautiful,woman
i tried filter and dinamic search but i was not able to visualize all the photos in my catalog without these labels
can i do it?
i did with filter , i select the 3 labels under labels and invert filter
but in the results there are photos with the label beautiful /black and white
thanks
Photo Supreme Evangelist ,windows 10 & macos Sierra & high sierra ,photosupreme 4, lightroom & photoshop cc
mphillips
Re: how can visualize all the image without these labels?
Post by mphillips » 14 Oct 13 11:35
Hi
If you add each label to the dynamic search and then right click on that label in the dynamic search and select Exclude from Search.
Then run the dynamic search
This may give you the results you want
MikeP
Mike Phillips
http://www.mikeandmorag.co.za
D800, CNX2, Supreme
mantras
Post by mantras » 14 Oct 13 16:50
mphillips wrote:Hi
MikeP
thanks!
do you know would be really nice the ability to select more labels with ctrl+click or shift+mouse click?
cheers
Post by jstartin » 14 Oct 13 18:43
mantras wrote:do you know would be really nice the ability to select more labels with ctrl+click or shift+mouse click?
You can click on a label and then press the space bar to add it to the dynamic search. I find this works very well.
The thing is, the way to get combinations of labels (and other properties) represented in the collection viewer is through dynamic search which includes AND/OR combinations and exclusion. A simple multiple selection of labels without the "extras" would be a backwards step. An interface to dynamic search that uses key/mouse combinations usually associated with multiple selection could be very confusing for users.
mantras
Post by mantras » 14 Oct 13 18:56
Hi Jim
thanks a lot
i did not know about the spacebar , did not find it in the quick manual
mantras
Post by mantras » 15 Oct 13 7:22
hi
use the space bar is the faster way to send to dynamic search ?
and to select many labels the faster way is dinamic search or filter?
do you think that click on a label and ctrl or shift would be better to select several labels?
thanks
