hi
i did notice a weird behavior and not smart security 6 and 5 64bit warn me
installing the last version , after i have authorizate flickrs , eset smart security warns me , the hips to be precise , about the code changed
is normal ?
download from the official site
thanks
weird behavior, nod warns me
Re: weird behavior, nod warns me
Mantra,
So ESET did the right thing
A message that a certain application has changed should concern you when nothing has changed, but an update is a change!eset smart security warns me
Noweidmic wrote:Mantra,
So ESET did the right thing![]()
it did NOT happen after the update
it did happen after i authorizate flickr , this is weird
maybe Hert can anwer
does photo supreme change his code with a flickr authorization completed?
thanks
Sorry, my fault.
... and then everything else would not matter anyhow
Regards,
Made me think you have done an update to the latest version...installing the last version
Regards,
No it doesn't. It does have to access the internet, of course, to get to the Flickr website. Maybe that triggers something?mantras wrote:does photo supreme change his code with a flickr authorization completed?
