After installing, Photo Supreme defaulted to "JPG than RAW" for selecting the main version of a file.
After changing the setting to "RAW else JPG" I reran the import. No effect.
I tried other settings and PS will not put the RAW file as the main version.
I followed instructions from other threads about using the Right Click --> Operations --> Version Detection to force this, to no effect.
Is anyone else having this issue? I want my RAW files to be the main version.
Main File Versioning not picking RAW
Re: Main File Versioning not picking RAW
Automatic Version detection follows a few requirements as outlined in the help:
http://manualsu.idimager.com/version_detection.html
I've already followed the instructions in the help to the best of my ability. PS is currently set to RAW FIRST, I've created new folders and copied RAW and associated JPG from "clean" (Not touched by PS) folders and the JPG is still picked as the main.
I double checked the preferences, ran the Version Detection, and it keeps the main version as JPG.
I'm stumped.
I'm stumped.
Are you running on existing version sets? If so, then the main version will remain unchanged. Destroy these sets first (right click -> Operations -> Destroy VersionSets)bruhsam wrote:and it keeps the main version as JPG.
The Good: Destroying the version set and reversioning works for existing image sets.
The Bad: This still does not effect new image imports. The JPG is being assigned as the main version.
An import profile has its own version setting. Make sure you configure the import to create versions the way you want it to
