Batch and Sequence
KeesdH
Batch and Sequence
Post by KeesdH » 26 Oct 12 16:55
What I want do do is batch rename a series of photos were the new filename starts with a sequencenumber.
What happens is that the batcher seems to pick its own way of sequencing the selected images and therefore the sequence of the output is different then the sequence of the input images.
So I filter the set of images I want to rename, then I select the first image, select all, run batch. It starts with the first selected image, then it takes the last image and goes back from there.
Strange, a bug, or do I mis something. Any help appreciated. And BTW this is different behaveour than in IDI.
Kees
