Out of Memory Saving D800 Files to JPG
mphillips
Post by mphillips » 19 Sep 12 13:07
Hi Hert
When I try and save a D800 NEF to a JPG - Original Size I get an out of memory error.
Regards
MikeP
PS. Windows 7
Mike Phillips
http://www.mikeandmorag.co.za
D800, CNX2, Supreme
jerrylewiiis
Re: Out of Memory Saving D800 Files to JPG
Post by jerrylewiiis » 25 Sep 12 16:29
I have the same problem... "Out of memory"
How can I do ?
Post by Hert » 27 Sep 12 21:42
Photo Glamour performs heavy duty tasks on the image, often requiring that several copies of the image are kept in-memory. Best to use slightly downsized versions of your images. You shouldn't get memory errors when working with images up to 4000x4000 pixels.
Post by fbungarz » 05 Oct 12 2:27
Seems not to be an issue just with PhotoGlamour, but as well with IDI...
jcldl
Post by jcldl » 28 Dec 12 9:59
I have exactly the same problem with my A77 . But I noted something strange. I take always jpg+raw from the same picture. Size from raw 23 mo, but in P glamour original size is 1616*1080 , I can save in jpeg without problem, but jpg (5 mo) has an original size of 6000*4000 so I have a problem. But if I treat raw picture with DXO software to have a jpg picture, original size is again 6000*4000 and I can't save because "out of memory".
ethan11james
Post by ethan11james » 21 Apr 15 6:49
i also have same problem if have any solution please let me know. even i format my memory also but still same and i have huge free space
