Copyright symbol
dickl
Copyright symbol
Post by dickl » 28 Mar 12 14:35
Alright! Now I can make changes! A couple of observations...
Copyright symbol shows ?? 2012 etc .. After a lot of experimentation, I found that option/command-c on my MacPro creates the copyright symbol, so I updated the copyright field. Looks ok until I sync? Then the ?? returns.
Secondly, the Apply button in detail only shows up if you select more than one image. Is that intended? ie making a change on a single image takes place immediately?
Dick
Re: Copyright symbol
Post by Hert » 28 Mar 12 16:10
dickl wrote:Secondly, the Apply button in detail only shows up if you select more than one image. Is that intended? ie making a change on a single image takes place immediately?
Yes, that is intended. The changes are applied automatically
