Way to display star ratings permanently?
dwphoto
Re: Way to display star ratings permanently?
Post by dwphoto » 28 Jun 13 20:17
Thanks David and Hert - that new code works and I love the combination of both seeing the stars plus the version colours - a really great tweak
cheers, Dean
David Grundy
Post by David Grundy » 29 Jun 13 3:08
Another alternative ... easier on my eyes because the stars are now always the same colour so I find it easier to spot what I'm looking for on a large page of thumbnails ...
thumbs stars v5.jpg (30.87 KiB) Viewed 5519 times
%code
var
  ACatItem: TCatalogItem;
  AVersionColor: String;
  AVersionShape: String;
  ARatingColor: String;
  ARatingStar: String;
  ARatingOnStar: String;
  ARatingOffStar: String;
  i: Integer;
begin
  result := '';
  ARatingColor := 'CCCCCCCC';
  ARatingStar := 'M 3.03,4.19883 L 2.996,4.22354 L 3.00909,4.26369 L 2.97501,4.2389 L 2.94086,4.26369 L 2.95394,4.22354 L 2.92,4.19883 L 2.96193,4.19883 L 2.97501,4.1589 L 2.98801,4.19883 L 3.03,4.19883 Z ';
  ARatingOnStar := '<img size="22" path="' + ARatingStar + '" pathfillcolor="' + ARatingColor + '">';
  ARatingOffStar := '<img size="22" path="' + ARatingStar + '" pathfillstyle="none" pathstrokestyle="solid" pathstrokecolor="' + ARatingColor + '">';
  AVersionShape := 'M 1,1 L 2,2 L 1,2 L 1,1 Z';
  if Catalog.FindImageCombined (ImageItem, ACatItem, False, vptNone) then
  begin
    AVersionColor := '#3FCCCCCC';
    if ACatItem.IsVersion then
      AVersionColor := '#FF40FF40';
    if (ACatItem._MainVersionGUID = ACatItem.GUID) and (ACatItem.VersionCount > 0) then
      AVersionColor := '#CCFF00FF';
    result := result + '<font color="'+ AVersionColor +'"><ind y="2">';
    result := result + '<img size="22" path="' + AVersionShape + '" pathfillcolor="' + AVersionColor + '">';
    result := result + '      '; //This line adds extra space after the version symbol
    result := result + '</ind></font>';
    result := result + '<font color="'+ ARatingColor +'"><ind y="2">';
    for i := 1 to ACatItem.Rating do
      result := result + ARatingOnStar;
    for i := ACatItem.Rating + 1 to 5 do
      result := result + ARatingOffStar;
  end;
  ACatItem.Free;
end;
%/code
I don't know yet how fonts and spacing are defined, so it's possible that anyone else using this might need to modify the line
to get sensible spacing between the version symbol and the stars. Or if the default font for thumbs info changes in future then this line also might then need to change.
... David
Post by fbungarz » 29 Jun 13 7:35
Hi all,
for some reasons this does not work, the bar still gets colored:
Post by Hert » 29 Jun 13 7:40
Frank,
The colored bar is the color label and this bar is outside of any script's control.
David's script shows a version indicator and the star ratings.
Post by fbungarz » 29 Jun 13 7:58
So why does his screenshot NOT show the bar??? Instead it shows little colored triangles - I thought that was the whole purpose of his modifying the script!
David Grundy
Post by David Grundy » 29 Jun 13 8:09
Hi Frank
The first line below your thumbnail is PSU's own standard display which shows with every thumbnail. This is coloured red because the photo is labelled as "red" (eg by pressing "Ctrl-1" when it's selected in the Collection Viewer, or one of the other methods for doing this). I don't know how to modify this line.
Well ... I do know one way to avoid it showing a red bar: the image could be NOT labelled as "red". ;-)
The second line is the output from the script. If you're using the first version of the script this would be a coloured bar with stars on it; if you're using the one I most recently posted it will just have the coloured triangle.
... David
[Edited for (I hope) improved clarity]
Preston B
Post by Preston B » 29 Jun 13 15:04
Hi Guys,
The output from this script looks great! However, not having used scripts in PSu before, where do I put the code? Please provide exact steps.
--P
Preston Birdwell
Columbia, CA
Post by fbungarz » 29 Jun 13 15:40
Hi David
so what causes the colors of the star respective triangle? I obviously falsely assumed they would be the output from the color bar, which is just as disturbing visually as the background bar of the stars.
I wish one could at least make it look like IDI.
Post by fbungarz » 29 Jun 13 17:04
I actually didn't notice that the colors of the triangle or stars denote the versions NOT the color label (of course !!!). Are these colors configurable per version, how? It did throw me off that your colors were different then mine...
Sorry for the confusion.
David Grundy
Post by David Grundy » 29 Jun 13 17:06
Hi Preston
In the Collection viewer, at the top-right corner of the view, there's an icon labelled "View". Click on this, and an option dialog opens underneath it.
The second title bar in the dialog is labelled "Custom Thumb Info". Underneath this there is a box where you can put in the script.
So, just copy the whole script in one step, and paste the whole thing into the box. You don't need to be able to read what's in the box. (If there's something already there you can remove it first, for example by clicking in the box, press ctrl-a to select all text in the box, and press Delete).
Once you put a script into one line, the thumbs will immediately update with the information (assuming it works). And an additional box for another script will appear below the one you just filled up, in case you want to add another line of info as well.
(BTW I couldn't find this in the manual; I did a forum search a few days ago because I also couldn't work it out!)
... David
David Grundy
Post by David Grundy » 29 Jun 13 17:21
Hi Frank
Indeed, I wanted to do this because I find it difficult to see the little version indicator tabs and the star number (with a thin font, dark on light, I can't see it well). My implementation only gets part-way there.
At present the triangles have the following meanings:
- dark grey (almost the same colour as the background) = no versions
- purple = main version
- green = any other version
I don't yet know how to identify any versions specifically except the main version.
The colours are defined in these lines:
ARatingColor := 'CCCCCCCC'; //This is the colour for the stars - pale grey
although it appears I forgot to specify "#" in this case. Ooops ... and ... hmmm, why does it still work?
AVersionColor := '#3FCCCCCC';// This is the colour for unversioned images
AVersionColor := '#FF40FF40';// This is the colour for non-main verisons
AVersionColor := '#CCFF00FF';// This is the colour for main versions
I got these colours with some trial end error; I was too lazy to figure out how colours work with 8 digits instead of the 6 I was expecting. If you fill these with alternative sets of hex digits, you'll get different colours, but as mentioned I don't know how to determine which specific version is displayed so the colours are probably the easy bit.
... David
David Grundy
Post by David Grundy » 29 Jun 13 17:32
Edit: I have removed the previous content of this post because it didn't make a sufficiently relevant point. It belongs to another thread, another time.
Instead let me just say that I don't use colour labels much. I agree the colour bars are more visually dominant than I would prefer, but it never occurred to me to suggest making it different! For most purposes, I have a private label category (ie my Manage DB labels are never written out to the files) for workflow statuses of various files, and for most other things which might otherwise have been done with colour labels.
Preston B
Post by Preston B » 29 Jun 13 19:41
Hi David,
Thank you for posting the steps for adding your code. It works great for me.
Just a thought, but you might want to post the code and the procedure in the Photo Supreme forum>Announcements>Tips for working with Photo Supreme thread.
Your script is very nicely done, indeed, and should be shared.
--P
Preston Birdwell
Columbia, CA
David Grundy
Post by David Grundy » 27 Jul 13 14:50
Here's another way.
I wanted to replace a row of stars with a specific shape for each rating. I suspect this is faster to process visually, especially when scanning visually for images with a particular rating. But I could easily be wrong.
I don't know if it's better, but anyway may as well add it to this list in this thread.
Rating square 2.jpg (66.64 KiB) Viewed 5371 times
In the example the ratings are
Row 1: 5,1,0,4
Row 2: 4,2,4,3
As before, the purple and green triangles show when something is a Main Version or Other Version respectively.
The proportion of the yellow square that filled in with yellow shows what rating the file has.
%code
// 2013-07-27 v6 Replace stars with a part-filled square
// 2013-07-13 v5b, modified colours
// 2013-06-30 v5a, split version indicator from rating stars
// 2013-06 early versions based on code by Hert
// Note to self: Colours seem to be specified as ARGB Hex
var
  ARatingNumber: Integer;
  ASetRatingColor: String;
  ARatingShape1: String;
  ARatingShape2: String;
  i: Integer;
begin
  result := '';
  ARatingColor := '#FFCFCF00'; //#### Yellow colour for rating shapes
  ASetRatingColor := '" pathfillcolor="' + ARatingColor + '" pathstrokestyle="solid" pathstrokecolor="' + ARatingColor + '">';
  ARatingShape1 := 'M 0,0 '; //#### First part of rating shape
  ARatingShape2 := ' L 5,5 L 0,5 L 0,0 Z'; //#### Last part of rating shape
  AVersionShape := 'M 0,0 L 1,1 L 0,1 L 0,0 Z'; //#### Triangle shape for the version indicator
  begin
//#### Show a shape coloured to indicated versions
    AVersionColor := '#FF333333'; //#### Dark gray colour for Solo (unVersioned) files
      AVersionColor := '#FF33FF33'; //#### Bright green colour for non-Main Versions
      AVersionColor := '#FFCC00CC'; //#### Purple colour for Main Versions
    result := result + '   '; //####This line adds extra space after the version symbol
//#### Show a shape to indicate the rating
    ARatingNumber := ACatItem.Rating;
    result := result + '<img size="22" path="' +  ARatingShape1;
    result := result + ' L '+inttostr(ARatingNumber)+' '+inttostr(5 - ARatingNumber)+' ';
    result := result + ARatingShape2;
    result := result + ASetRatingColor;
  end;
  ACatItem.Free;
end;
%/code
... David
ykuendig
Post by ykuendig » 13 Oct 13 13:27
I have also modified the script a bit to show file-size, gps-state and recipe in addition.
For all of you who are interested:
%code
var
  i: Integer;
begin
  result := '';
  ARatingColor := '#CCCCCCCC';
  ARatingOffStar := '<img size="19" path="' + ARatingStar + '" pathfillstyle="none" pathstrokestyle="solid" pathstrokecolor="' + ARatingColor + '">';
  begin
//#### Show Versioning Triangle
    result := result + '<font size="08" color="'+ AVersionColor +'"><ind y="2">';
//#### Show Star Rating
    result := result + '<font size="08" color="'+ ARatingColor +'">';
      result := result + '<ind y="2">' + ARatingOnStar;
      result := result + '<ind y="3">' + ARatingOffStar;
//#### Show File Size
    result := result + '<FONT size="08" color="#CFFFFF00"><ind y="3">%ImageFileSizeShort';
//#### Show GPS indicator
    if ImageItem.HasGPS then
    result := result + '<FONT size="08" color="#FF40FF40"><ind y="3">GPS'
      else
    result := result + '<FONT size="08" color="#3FCCCCCC"><ind y="3">GPS';
    result := result + '</ind></FONT>';
//#### Show Recipe indicator
    if ImageItem._HasRecipe then
    result := result + '<FONT size="08" color="#FFFF4040"><ind y="3">R'
      else
    result := result + '<FONT size="08" color="#3FCCCCCC"><ind y="3">R';
//    result := result + ' '; //This line adds extra space
  end;
  ACatItem.Free;
end;
%/code
Yves
