Saving changes
Mousetro
Saving changes
Post by Mousetro » 28 Aug 12 18:20
Okay I just bought the app and I made changes to the pic but when I save it and preview the image or load it into iPhoto they don't show up. I looked in help but there is nothing there that really is helpful.
Re: Sving changes
Post by Hert » 28 Aug 12 20:57
Did you specify a filename with extension in the save dialog?
What are the image dimensions of your original (WxH)
What dimensions did you select as save option?
Thank you
