Version 6.7 Access Violation Error
Anthony
Post by Anthony » 04 Dec 21 13:47
I have just upgraded to version 6.7.0.4064 and am encountering constant Access Violation errors when I double click on a thumbnail or open the file (raw CR2 or CR3 or jpgs) using Adjust. This unfortunately makes Photo Supreme pretty unusable at the moment.
I have sent the exception and hope that this can be fixed soon. I had occasional exceptions before.
Re: Version 6.7 Access Violation Error
Post by Hert » 04 Dec 21 15:31
The version on the website is reverted to 6.6.
However, in the 6.7 version I cannot reproduce an exception. What OS are you using?
Post by Hert » 06 Dec 21 14:55
6.7 is back online. Now at build 4074.
pattcz
Post by pattcz » 08 Dec 21 23:10
6.7.0.4080 exception on every start.
EDIT : Fixed in 6.7.0.4082 Thanks Hert.
Anthony
Post by Anthony » 10 Dec 21 10:48
Thanks Hert, as ever, for fixing problems so quickly!
