re-dating files - problems
Post by Stephen » 14 Oct 21 12:56
I forgot to reset a camera due to change in time zone and I'm having problems re-dating the files.
The re-dating panel has multiple options and I'm unsure which I need as my tests have not worked. I shoot RAW + JPG simultaneously and one test just re-dated the JPGs and not the RAWs, so I will start again.
Any tips please?
Re: re-dating files - problems
Post by Hert » 15 Oct 21 7:22
Redating works on the selected files. To redraw a JPG and RAW file you need to select them both.
Check the results in the Details panel-Technical
