Help with editing the custom thumbs info needed.
Ulrich
Post by Ulrich » 19 Aug 21 7:15
I would like to add a new custom thumbs info line that shows if a file has GPS Information added or not.
I know this is easyly done with %ImageHasGPS. This results in "yes" or "no" in that line.
For the sake of clarity ( because I would like to add some more information on a single line) I would like to show an indicator only if there is a GPS Info.
Perhaps "GPS" if the info is present and nothing if not.
I tried to start with the pascal script language and tried many different versions of
%code
begin
	if ImageHasGPS then 'GPS';
end;
%/code
All of them failed...
What is done wrong?
https://repository.idimager.com/documentation.asp doesn't help me find the problem.
Is there any further source where I can try to learn more about the photo supreme API?
A readable Object-Model description? Color Code Listings? Examples for beginners?
Re: Help with editing the custom thumbs info needed.
Post by Mke » 19 Aug 21 15:23
Through playing based on other code posted here, I've come up with something that more-or-less does what you want:
%code result := 'GPS %ImageHasGPS{encode=html}' %/code
However (until now) I've coded nothing in Pascal, and not much in anything else, so there's probably a better solution.
Ulrich
Post by Ulrich » 19 Aug 21 17:18
Hi Mke,
thank's for your help, but that's not was I was exactly looking for.
If there is no GPS Info in the file, nothing should be shown, if there are GPS Infos in the file, I would like to see an 'GPS' Indicator.
Your solution shows "GPS Yes" or "GPS No", which is more or less the same than 'GPS %ImageHasGPS' without pascal code.
Thank you anyway
Ulrich
Post by Ulrich » 20 Aug 21 6:24
I've got it!
%code
  if ImageItem.HasGPS then
  begin
      	result := '<font bgcolor="#FF0000" color="#FFFFFF" bgradius="0.3">&nbsp;&nbsp;' + 'GPS' + '&nbsp;&nbsp;</font>&nbsp;';
  end;
%/code
Post by Hert » 20 Aug 21 8:35
Great. Here's how to do it without scripting:
%GPSExists<font bgcolor="#FF0000" color="#FFFFFF" bgradius="0.3">&nbsp;&nbsp;GPS&nbsp;&nbsp;&nbsp;</font>%/GPSExists
