Customizing the Thubnail-Style Information
Ulrich
Post by Ulrich » 13 Aug 21 7:04
Hi there,
I'd like to customize the information below the displayed thubnails.
Of cause I can click through the displayed fields (in the custom dialog) and use them, but I can't find any manual with further information on that.
Is there a detailed description about the possibilities anywhere?
My goal is to display the entire path of the image without the first 18 characters of the path, as these are always the same and otherwise the right part of the path would be cut off in the display.
Is that possible?
Is there any LEFT(); MID(); RIGHT(), that could be used, or something equivalent?
Greetings
Ulrich
Re: Customizing the Thubnail-Style Information
Post by Hert » 13 Aug 21 7:44
Read more about macros in the Macro Commands manual (click ? icon in the left sidebar)
To get the file path without the first 18 chars you'd need to use the mid parameter; e.g.
%FilePath{mid=19,2000}
Ulrich
Post by Ulrich » 13 Aug 21 7:53
Great!!
Thank you, Hert.
