saved batch can no longer be changed
Ralf
Post by Ralf » 20 Jul 21 15:59
I've put together a batch
1. I create a batch
2. under "rename file" is a script that I have saved
3. run works
4. I open the batch so everything is messed up and it can no longer be changed
my script is:
  a: = ''
  a: = '% xmp: photoshop: headline'
  if a <> '' then
   result: = 'E: \ Testbilder \% FileFoldername {mid = 1,3} x \% YYYY \% mm \% yyyy% mm% dd-% xmp: photoshop: headline \% yyyy% mm% dd-% hh% nn% ss.% FileExtension '
  else
    result: = 'no headline available';
:?: I have two questions :?:
1. What am I doing wrong
2. How can I display a message box if the field is not filled?
My Version is 6.3.0.3808
Ralf
(Excuse my english)
Ralf
Re: saved batch can no longer be changed
Post by Ralf » 22 Jul 21 8:41
I have to ask again here, does anyone else have the problem that when a batch is saved it becomes very confusing and no longer works
Ralf
(Excuse my english)
Post by Hert » 22 Jul 21 10:08
Use this instead:
  a := '%xmp:photoshop:headline{encode=quotes}';
  if a <> '' then
    result := 'E:\Testbilder\%FileFolderName{mid=1,3;encode=quotes}x\%YYYY\%mm\%yyyy%mm%dd-%xmp:photoshop:headline{encode=quotes}\%yyyy%mm%dd-%hh%nn%ss' + ImageItem.FileNameExtension
  else
    result := 'no headline available';
This also takes care of errors when there are quotes in the existing photoshop:headline text.
A rename operation is not the way to detect if the field is filled or not.
You do a rename operation with a rename rule that generates 'no headline available' as the file name to use, and that is what PSU will use to rename the file.
Ralf
Post by Ralf » 22 Jul 21 13:11
thank you, that works fine, but the "Rename file" window is completely dismantled after saving. A second time you can then no longer change or use it.
Ralf
(Excuse my english)
Post by Hert » 22 Jul 21 13:16
After changing the script with the code I sent you, you should also re-save the batch so that the change is saved.
Ralf
Post by Ralf » 22 Jul 21 13:43
I think I'm doing something generally wrong in my attempts at a script
if i take your code it works, i take another one always this error comes out of the window above.
here the script adjusts something so as not to run into the error of the field.
sorry if I act too stupid;)
b :='%FileFoldername{mid=1,2}';
 if b > 19 then
  result := 'E:\Testbilder\%FileFoldername{mid=1,2}\%YYYY\%mm\%FileFoldername\'  + ImageItem.FileNameExtension;
 else
   result := 'wrong directory';
Ralf
(Excuse my english)
Post by Hert » 22 Jul 21 14:53
var
  f, b: WideString;
begin
  f := '%FileFolderName{encode=quotes}';
  b := MidStr(f, 1, 2);
  if IsValidIntNumberString(b, False) then
  begin
    if StrToInt(b) > 19 then
      result := 'E:\Testbilder\' + b + '\%YYYY\%mm\' + f + '\' + ImageItem.FileNameExtension
  end;
end;
