Installation on terminal server / XenDesktop environment
frank.evers
Post by frank.evers » 19 May 21 12:01
Hello everyone,
I'm new here. If I'm doing somehow wrong feel free to tell me, I'll appreciate.
So I'm searching for a DAM solution for some of our users and Photo Supreme might be the right product to pick. However, as we are running a Citrix XenDesktop environment based on MS Windows Server 2016 terminal servers i need to make sure that i can run several instances of the client software on a terminal server without any conflicts, also taking into account that there are probably several active SQL-connections from one machine at the same time.
Does anyone here have experience with that setting?
Thanks in advance,
Re: Installation on terminal server / XenDesktop environment
Post by Hert » 25 May 21 8:36
A very warm welcome to the forum.
It is possible to run multiple instances of the client software from the same machine. The database connections are not restricted.
