Verify folder grayed out after new update
johnbarrett
Post by johnbarrett » 22 Apr 21 13:43
Screenshot 2021-04-22 135900.jpg (22.91 KiB) Viewed 261 times
As above, opened program, told update available, installed it but verify folder now not working. One PC is now rebuilding everything and a laptop has red marks on marking every folder. Not safe to update until this is sorted
johnbarrett
Re: Verify folder grayed out after new update
Post by johnbarrett » 22 Apr 21 15:18
Told buy support not to "Map to the correct physical path" (bit late as am running that now)untill an update is producd sorting this out.
New version sorted laptop but not PC which rebuilt everything that a bigger mess than befor the 2nd update.
Sorted now reinstalled a disk imige.
andrew.heard
Post by andrew.heard » 23 Apr 21 0:06
I *think* the same happened to me. I saw the red overlay on the Folder icon, although no explanation from anyone what the reason was. I tried re-mapping the base folder (which returned 0), and then after a switch to a different tab then back again, the red overlay was gone.
johnbarrett
Post by johnbarrett » 23 Apr 21 10:00
Andrew you were lucky, my remapping leapt into actually recreating everything which then with the update produced to remove the problem blocked a catalogue restore. Hert came back with to manually copy my backup over but I was restoring a disk image by then that sorted, with a bit of renewing updates of other programs, the problem.
BertiIrmo
Post by BertiIrmo » 23 Apr 21 10:29
After the update to 3667 I also had this problem without doing anything else. A reassignment was always only possible for a short time. The update 3667 I had also not started with right-click "Run as administrator".
After the update to 3771 the assignment worked again.
