Search for images in multiple categories using Search window.
allthepix
Post by allthepix » 21 Apr 21 20:00
I can display images that are in both category_a and category_b by clicking on category_a and CTRL-ALT-CLICK on category_b. Each image displayed is then in both categories.
Is there a text equivalent of this selection that can be typed in the search window at top right corner to achieve the same selection?
Thanks!
Using Photo Supreme 6 (64 bit) to help manage family history images eg. from Church Registers and censuses.
Re: Search for images in multiple categories using Search window.
Post by Hert » 22 Apr 21 15:08
The Search Manual explains the advanced search capabilities of the Search Box by using search domains.
To get the result of CategoryA and CategoryB you could use something like
CategoryA+CategoryB@CAT
allthepix
Post by allthepix » 22 Apr 21 15:41
Yes, I have the QuickStart-Searching.pdf manual and have been trying various options but just can't get the search field to perform the selection.
Here's my example - there are 65 images with Category of Hawridge (a parish in Buckinghamshire.) Only one of these also has a Category of Pending (which I'm using to record that I've not yet finished evaluating the image.)
If I click the category of Hawridge and Ctrl-Alt-Click the category of Pending then I get only 1 item selected which is correct. If I search on PENDING+HAWRIDGE then PS returns 65 items which is not correct.
I've tried adding parenthesis, spaces, changing the case and adding @CAT or @PROP to the search but I just don't seem able to get the search to work.
It would be really helpful if you could kindly advise?
Update : I've also managed to get to where I want with Dynamic Search. I'm a new user and gradually exploring the functionality. I just wonder why I can't achieve what I want with the Search field?
