upgraded to V6 and re-mapping folder does not work
andrew.heard
Re: upgraded to V6 and re-mapping folder does not work
Post by andrew.heard » 01 May 21 0:18
I've just upgraded from Photo Supreme-64 6.0.0.3657 to 6.1.0.3677 & again I see the Folders icon is shaded red which I assume indicates some invalid mapping issue. This time I took a screen cap - see attached. Nothing has changed that I'm aware of. I right+click the "data" folder > Map to physical... > was already correct (of course) > msgbox: "Mapped 0 folders" > all folders now have 0 for their counts. I refreshed but still zero. So I now expand the C drive folder until the "data" folder is displayed, right+click > Make this the Top Level Folder, and again sorted.
2021-05-01 09_17_15-Window.jpg (8.92 KiB) Viewed 151 times
2021-05-01 09_13_30-Window.jpg (27.56 KiB) Viewed 151 times
Post by Hert » 01 May 21 10:11
This was fixed in build 3671. If this persists then you probably did a folder relocate in build 3657. I recommend that you restore a catalog backup created before the relocating in build 3657. Sorry for the inconvenience
andrew.heard
Post by andrew.heard » 02 May 21 3:00
Thanks Hert, but my screen capture intentionally shows I am using 3677. I hadn't done a folder relocate. As per previous experience, on 2nd run of PSu the issue has fixed itself.
