Adjust panel: rotation: recipe applied twice?
jd
Post by jd » 09 Apr 21 23:37
I used the Adjust panel to rotate an image (90 degrees CW), saved the recipe, and exited the Adjust panel (went back to thumbnails). When I view the image, I see the recipe icon in the upper left corner and the image is displayed with the expected rotation.
When I reopen the Adjust panel for the image, I expect to see the image with that rotation. Instead, I see that the image is rotated another 90 degrees CW (180 degree change from the original), as if the recipe is applied twice.
Why is this happening?
PS 6.0.0.3556
Re: Adjust panel: rotation: recipe applied twice?
Post by Hert » 12 Apr 21 10:56
I was able to reproduce this. Apparently it happens when you open in Adjust mode from inside the View mode. It doesn't happen when opening in Adjust mode directly from the thumbnail. This will be fixed
