searching in Descriptions
vkfoto
Post by vkfoto » 21 Mar 21 2:00
I can export the Descriptions in a CSV file and then search in that but can it be done inside PSU?
In the Dynamic Search, I see Description is limited to Headline and Description Writer. Is Description a field too far?
Re: searching in Descriptions
Post by Hert » 21 Mar 21 6:49
You can use the upper right search bar to search for *everything*. Tip; Also read through the Searching manual
