Unusual F-Number, Focal Length, Exposure Time Format
Alfons
Post by Alfons » 25 Feb 21 17:03
I noticed the below formats for F-Number, Focal Length, Exposure Time (build 6.0.0.3575). Any idea how to correct that?
Re: Unusual F-Number, Focal Length, Exposure Time Format
Post by Hert » 26 Feb 21 10:00
What you see there is the "unhandled" value as it exists in the metadata. In the next build this will be corrected.
Post by Hert » 27 Feb 21 9:41
Please update to build 3579. Download from the website, there's no web update trigger.
apanella
Post by apanella » 28 Feb 21 14:10
Alfons, thanks for asking he question. Hert, thanks for the update. ( I just figured this was something I was doing wrong. )
In case it helps, this update also fixed the same issue with Nikon Z6 and Nikon Z6II based files.
