Rename Files with camera model adds unwanted blank spaces in new name
User avatar
OldRadioGuy
Post by OldRadioGuy » 22 Feb 21 17:10
Set up a formula to produce a rename like this:
Instead, the formula returns
PEN-F _21-02-22_01.JPG (10 blank spaces after PEN-F but phpBB appears unable to display 10 blank spaces)
1. Operations -> Rename Files -> Rename Window
2. Selection of Camera Model (%exif:Model) as part of the rename formula produces 10 blank spaces at the end of this section
Tested with images from an Olympus E-M1 Mark III camera and an Olympus PEN-F on ORF and JPG files. When I substituted a lens code for the camera model the rename worked correctly without the extra blank spaces.
Photo Supreme 6; DxO PhotoLab; ON1 Photo RAW; ExposureX; Affinity Photo; PhotoLine; macOS Big Sur; 27-inch iMac, Retina 5K
Re: Rename Files with camera model adds unwanted blank spaces in new name
Post by Hert » 22 Feb 21 17:20
Some cameras fill the name with spaces. You can have them removed by trimming the value;
%exif:Model{trim=y}
Or select it from the menu:
User avatar
OldRadioGuy
Post by OldRadioGuy » 23 Feb 21 5:55
Thanks, Hert.
