PosgreSQL 13 Configuration
Dismayed
Post by Dismayed » 19 Feb 21 20:16
I edited the config file when I installed PostgreSQL 13, and discovered that it's different than in the PSU documentation. It contains entries for scram-sha-256 security, instead of for md5. Am I correct to assume that what I've configured below will work with PSU 6 Server?
# TYPE DATABASE USER ADDRESS METHOD
# "local" is for Unix domain socket connections only
local all all scram-sha-256
# IPv4 local connections:
host all all 127.0.0.1/0 scram-sha-256
# IPv6 local connections:
host all all ::1/128 scram-sha-256
# Allow replication connections from localhost, by a user with the
# replication privilege.
local replication all scram-sha-256
host replication all 127.0.0.1/32 scram-sha-256
host replication all ::1/128 scram-sha-256
~ Will Rogers
Dismayed
Re: PosgreSQL 13 Configuration
Post by Dismayed » 19 Feb 21 20:50
OK. I finished the installation, and PSU seems to connect with PostgreSQL 13 without problem.
~ Will Rogers
Username
Post by Username » 20 Feb 21 7:14
If you installed V6 as a new clean install, setting scram-sha-256 will instruct the postgres to use SCRAM method for authentication.
If you upgraded a V5 or previous postgres which used the md5 method, setting scram-sha-256 willl not effect the stored passwords or auth method. But if you do a password reset and ask the user to set a new password, the scram method will be used instead.
PSu Server 6 & Postgres 12 on macOS 10.15
PSO 5 on Windows Server 2016
- I'm the user
Dismayed
Post by Dismayed » 21 Feb 21 16:42
Username wrote:
20 Feb 21 7:14
Thank you for the explanation. I backed up my v5 database, uninstalled PSU v5 and PostgreSQL 12, and then did clean installs of PostgreSQL 13 and PSU 6. It all seems to work well.
~ Will Rogers
