Issue with assigning Album Display
KeesdH
Post by KeesdH » 16 Feb 21 18:53
V6
I tried to set the rule for assigning Album Display, however the drop down list is empty. It does work for al the other version placeholders.
I suppose this is a bug??
KeesdH
Re: V6: Issue with assigning Album Display
Post by KeesdH » 17 Feb 21 17:38
Album display just disappeared. Most of my version sets contain a version "album display", however the album display disappeared as a version type. Anybody has the same experience. Is this a setting or a bug??
Post by Hert » 17 Feb 21 18:26
It’s already resolved for the next build.
KeesdH
Post by KeesdH » 18 Feb 21 12:12
I instlled build 3549. The dropdown list in the versieplaatsbeheer is back. However when I look at my versioned pictures it still does not show them as album display type.
Also there is only a choise between webdisplay and slideshow from the version tab. Not sure why that is.
Post by Hert » 18 Feb 21 12:30
Album Display shows fine here.
Could it be that you have the others disabled? Check the checkmarks in front of the Placeholders
