Photo Supreme V6 Cannot Change Document Title
notme2000
Post by notme2000 » 16 Feb 21 16:37
Hi everyone,
I upgraded to v6 today, and now whenever I try to change the Document Title of an image, when I hit save it just reverts back to the original title. Does anyone know what I'm missing here? It worked fine in V5. I can't even change old images that I named in V5. I've confirmed none of the images are read-only, and I've tried launching Photo Supreme as admin, no luck. Anyone have any suggestions?
notme2000
Re: Photo Supreme V6 Cannot Change Document Title
Post by notme2000 » 16 Feb 21 17:36
If anyone has any suggestions I'd be extremely grateful. This undermines the entire purpose of the program for me, rendering it pointless.
notme2000
Post by notme2000 » 16 Feb 21 17:48
After experimenting, it seems I can make the changes on the INFO tab by creating a predefined field and referencing the Document Title field from there. However if I try to make the changes from the DETAILS tab, even if using that same custom field, it doesn't work. Seems like a bug related to the DETAILS tab.
Post by Hert » 16 Feb 21 17:52
By default, and as per specs, the title should contain the reference to the document. For a file typed resource
that is the file name, hence why psu writes the file name in the title. There is a registry tweak to switch that off. Check here; https://michaelweidner.com/psu/
User avatar
OldRadioGuy
Post by OldRadioGuy » 16 Feb 21 17:54
notme2000 wrote:
16 Feb 21 16:37
Hi everyone,
I just double-click on the document name below the thumbnail and can change the name with no problem in V6.
Photo Supreme 6; DxO PhotoLab; ON1 Photo RAW; ExposureX; Affinity Photo; PhotoLine; macOS Big Sur; 27-inch iMac, Retina 5K
notme2000
Post by notme2000 » 16 Feb 21 18:02
Thanks Hert,
Was there a change from v5? I used to be able to change the Document Title to something different from the DETAILS tab without issue, now it only works from the INFO tab using a predefined field. Even when I go to my older photos, where the document title is already changed to something other than the filename, I still can't change it from the DETAILS tab.
Post by Hert » 17 Feb 21 8:52
I was finally able to reproduce this one. Thank you for reporting
notme2000
Post by notme2000 » 17 Feb 21 14:18
No problem, I can confirm it is fixed in latest! Thanks :)
