Hi - I've just purchased PSu (Windows), it seems to be a great and powerful software.
The first problem I met is with import : when I select "Create catalog labels with folder names" (full folder structure), the keywords I had already put in xmp-lr and xmp-dc are deleted. I started this test with all sync settings reset and then tried many other settings but I allways get the same result : my keywords are replaced by the folder names.
Is there a solution to this issue ? Am I doing something wrong ?
Xavier
Import & Create catalog labels with folder names
Re: Import & Create catalog labels with folder names
Hi Xavier, a warm welcome to the forum.
I'd have to check that here. For now, you can switch that option off in the Import Module and use "Right Click on selected thumbs -> Run Script from Repository -> Catalog -> Folder Name to Catalog Label".
After I've checked this here, I'll get back to you
Thank you Hert for your quick answer. I'll try this.
And maybe soon come back with other questions or problems
Hi Xavier, I was able to reproduce this one. It will be fixed in the next build.
