Logging into Smugmug every time
Larry56
Post by Larry56 » 01 Jan 21 22:31
PSu 5.6.0.3383 on Macbook Catalina 10.15
Every time I click on Share->Smugmug I have to re-login before uploading and PSu doesn't seem to save previous approvals. Anyone else? Any have an idea what would cause not saving prior approvals?
Re: Logging into Smugmug every time
Post by Hert » 02 Jan 21 0:18
Authenticate in your Sharing profile. If the sharing profile contains your authentication then it will use that. If your sharing profile doesn't include authentication then you'll be prompted. To do so, right click on your SmugMug profile and select "Details". Then click the authentication to start you rlogin. Then save the profile.
Larry56
Post by Larry56 » 03 Jan 21 1:21
When I click on Details it already say "authenticated as Larry" but when I try to upload I have to go through the authentication steps each time.
Larry56
Post by Larry56 » 04 Jan 21 17:02
I created a new profile and that one I don't have to authenticate each time. I'll delete the other profile but I can't see any difference between them.
Post by Hert » 04 Jan 21 17:41
That's great. It could also be that the old profile needed re-authentication, for instance when SmugMug invalidated the login (maybe they have a max period). Try to logout in the profile and authenticate again.
Larry56
Post by Larry56 » 04 Jan 21 19:55
I wish I'd thought of that Hert. Thanks for that suggestion. I still one one old profile I and will try to to re-authenticate after disconnect to see what happens.
