Because of the way the current ly applied labels are presented in the Label screen, when adding a new label the whole set of Recently Used will jump down when an extra line is needed to show all of the applied labels. When applying several labels, I will sometimes end up clicking on the wrong one because the selection has shifted down. Is there a way to freeze the size / location?
I also like the suggested labels but since they are not in any obvious order, finding one requires I read every suggestion to see if it might apply. Sort of negates the quick selection opportunity since typing could be faster. Could they be in alphabetical order like the Recently used labels?
Recently used and Suggested labels.
Re: Recently used and Suggested labels.
There's no way to prevent that. When a new label is created, that becomes a "recently used" label. And since the most recently used one is at the top, the rest shifts down.
They are ordered by the level of likelihood of being related to the labels already assigned.I also like the suggested labels but since they are not in any obvious order,
I have to agree with this its a real pain
The number of times I have had the mouse waiting to click over a label only to find I have clicked the wrong one
Would it be viable to have a fixed size pane so that the panes and labels below wouldn't move down ?
I appreciate that this would then involve scrolling the top pane, but this pane size could be adjusted when the panes are redrawn so that all labels are displayed and then it would only be necessary to scroll
or
maybe allow extra space in the top pane so that perhaps an extra line or two can be accommodated without having to cause the pane to expand as frequently ?
or
+1G8DHE wrote: ↑31 Dec 20 10:45I have to agree with this its a real painThe number of times I have had the mouse waiting to click over a label only to find I have clicked the wrong one
I had already suggested this in Mantis for the V4 because it annoys me to constantly confirm wrong ones
https://mantis.idimager.com/view.php?id=3338
+1
+1
Ralf
(Excuse my english)
(Excuse my english)
Yeah, I remember bringing this up before too (or commenting on someone's post). Agreed that this makes labeling slower and annoying.
+1
Another possible fix would be to apply the label as soon as the click occurs... the problem is that there is processing in between the click and assignment.
+1
I agree that it could be slicker; it's actually been a suggestion since V3: https://mantis.idimager.com/view.php?id=2904
