PSU often crashes on me. It is usually the same type of crash.
IDimagerSU(4085,0x1074c6e00) malloc: *** error for object 0x600003908f70: pointer being freed was not allocated
I have attached the entire crashlog in case it is of value.
Often occurring crash
- PSU Crash.txt
- (72.7 KiB) Downloaded 10 times
Re: Often occurring crash
Any idea at what point that happens? Can you reproduce this?
I have seen it happen while it is building previews and synching, and I click on something. Hard to say what causes it.
I get the same type of crash when I try to login after a quit or crash or force exit, and there are no license available, and it says it will quit. Then I get the same crash. That case is maybe the easiest to reproduce.
