Can't create new label in Label search
Larry56
Post by Larry56 » 08 Nov 20 6:24
In the past when I am in Labels and I type a name in the search field if the name is not found (CREATE NEW) is displayed next to whatever I've typed and pressing Return opens a dialog box to complete the label information. Today though, while (CREATE NEW) is displayed pressing Return doesn't do anything and I can't get the dialog box to open pressing other keys. This just started with v5.6.0.3242 on MacBook Catalina 10.15.7.
Anyone else have same problem?
Re: Can't create new label in Label search
Post by Hert » 08 Nov 20 11:11
Works fine here on Catalina 10.15.7.
Maybe you didn't select the CREATE NEW option from the drop down (either click it or press arrow down to select it and then enter)
Larry56
Post by Larry56 » 08 Nov 20 17:23
Works fine now using the drop down CREATE NEW but I could swear that the CREATE NEW showed in the search box. Or maybe I had too much coffee yesterday.
Thanks, Hert.
emha
Post by emha » 22 Nov 20 13:59
Is the same here.
If its happen, I close PS, start it new, and its work again how expected.
