to filter for the two fields at the same time?
Ralf
Post by Ralf » 04 Nov 20 1:55
In the view under the thumbnail, among other things display the little hints below
% code if Catalog.ImageHasXMPProperty (ImageItem, 'ics: AreaTags') then result: = '<FONT color = "# 00324A" bgcolor = "# FF0000"> AREA </font>';% / code
% code if Catalog.ImageHasXMPProperty (ImageItem, 'Iptc4xmpExt: PersonInImage') then result: = '<FONT color = "# 00324A" bgcolor = "# 80D6FF"> PERS </font>';% / code
Is it somehow possible to filter for the two fields at the same time, so
Ralf
(Excuse my english)
Re: to filter for the two fields at the same time?
Post by Hert » 05 Nov 20 11:20
Not sure what you're trying to achieve here? You want the same output but differently?
Ralf
Post by Ralf » 05 Nov 20 12:46
yes, that was a bit awkward. The fields are not relevant, they were just an example. My aim is to check and display 2 fields (no matter which ones are currently needed)
Ralf
(Excuse my english)
Post by Hert » 05 Nov 20 13:44
You mean something like this?
%code
  result := '';
  if PublicCatalog.ImageHasXMPProperty(ImageItem, 'ics:AreaTags') then
    result := result + '<FONT color="#00324A" bgcolor="#FF0000"> AREA  </font>';
  if PublicCatalog.ImageHasXMPProperty(ImageItem, 'Iptc4xmpExt:PersonInImage') then
    result := result + iif(result = '', '', ' ') + '<FONT color="#00324A" bgcolor="#80D6FF"> PERS  </font>';
%/code
Ralf
Post by Ralf » 06 Nov 20 9:46
yes, exactly that. Thanks I can go on with that and make my life easier.
Great hobby and software :)
Ralf
(Excuse my english)
