GPX track start and end date/time both the same
rgifford
Post by rgifford » 24 Oct 20 14:26
When I select a GPX track to tag my photos the start and end date shown are both the same. It shows the end date.
As a test I have opened previous tracks which have displayed correctly and they also show the same date/time twice, showing that this isn't a problem with the track itself.
Re: GPX track start and end date/time both the same
Post by Hert » 25 Oct 20 11:23
Thank you. This is a display issue introduced after the introduction of supporting multiple GPX files (you can select multiple GPX files in the open dialog since build 3157). The start time display issue is fixed for the next build.
