Apply Import detail profile icon missing bug
Larry56
Post by Larry56 » 20 Oct 20 3:13
When I attach an SD card and open PSu (5.6.0.3197) on my Macbook Pro my routine is to select Import to catalog from the menu. When it import dialog opens I select the appropriate profile (as an example Sony A7iii) and then I go to more settings to confirm. By default it has Apply Import Detail Profile checked but the icon to the right is missing along with Apply catalog labels icon. The only way to get it display is to select the same profile from the Profiles selector at the top of the screen and then the icons appear.
I assume it's a bug as the icons were always there in previous versions, as far as I can recall.
Can anyone confirm so I can be sure it's not just something with my system?
Re: Apply Import detail profile icon missing bug
Post by Hert » 20 Oct 20 15:17
You can download and install the latest 3205 build from the website.
Larry56
Post by Larry56 » 20 Oct 20 16:05
Thank you.
