Photos being duplicated
User avatar
Tom Husband
Post by Tom Husband » 20 Sep 20 11:53
When I drag a set of versioned photos to another folder sometimes the group is duplicated so I have the same files in the original and in the folder I dragged them to. The versioned group will usually have a RAW, TIF, JPG and sometimes an afphoto (Affinity). If I delete one group then all are deleted.
edit: When I attempt to move it says files already exists and would I like to assign a unique name. If I do it will change the name of both versioned groups but not move anything. Weird.
Re: Photos being duplicated
Post by Hert » 20 Sep 20 12:53
Try pressing F5 to refresh the active collection after the move.
User avatar
Tom Husband
Post by Tom Husband » 20 Sep 20 18:55
Hmm, F5 doesn't make any difference. I can assign a unique name but then it just appears in both folders.
User avatar
Tom Husband
Post by Tom Husband » 22 Sep 20 13:32
This has happened several times now and all the duplicates were versioned before I attempted to drag and drop to another folder.
Now I've been renaming folders so it could be that somehow duplicates were created but with the same file name? I don't see a way to delete one of the duplicates either. I can't simply delete as it will delete all files. If I attempt to drag and drop again it wants to create a unique name but all that happens is both files are renamed but nothing is moved.
Post by Hert » 23 Sep 20 12:49
I see what's going on here. You're dragging a versioned item to a folder. That will only move that one dragged file to the target folder, not the other files in the same version set (files in a version set don't *have* to be in the same folder).
That is probably what's confusion you.
In the next update a change will be implemented:
1. When dragging a version set to a folder then all images in a set are dragged if the preference for version display is set to "Always stacked"
2. When dragging a version set to a folder then only the selected image from the set is dragged if the preference for version display is set to "Only in Categories"
The same applies for "copy/paste shortcuts
User avatar
Tom Husband
Post by Tom Husband » 23 Sep 20 15:43
Got it. Thanks a lot.
Falconartist
Post by Falconartist » 11 Jan 21 8:12
Hert wrote:
23 Sep 20 12:49
