Apply colours to 'types'
Rhod
Post by Rhod » 27 Jul 20 10:52
Hi - is it possible to apply colours to the borders of 'types' thumbnails so that I can tell at a glance whether the image is a jpg, tiff, raw, dng etc.? I tried a search but nothing found.
Rhod
Re: Apply colours to 'types'
Post by Hert » 27 Jul 20 11:02
Not exactly what you’re asking but you can enable custom thumb lines and add a line that shows the type. Find custom thumb lines in the View button, upper right.
Rhod
Post by Rhod » 27 Jul 20 12:53
Hert wrote:
27 Jul 20 11:02
Sorry to be a dunce but I've looked through every item in the 'Custom Thumb Info' and I can't see 'Custom Thumb Line'. Can you tell me exactly where it is?
Rhod
Post by Hert » 27 Jul 20 15:04
Here's a sample. Does that help?
Rhod
Post by Rhod » 27 Jul 20 16:34
That's great - thanks Hert. Sorry for being a bit dumb! :)
