Label and Describe?
LifeIsLong
Label and Describe?
Post by LifeIsLong » 08 Jul 20 11:35
Is there any way to display the labels panel and select details fields? I would love to be able to label and type a description without having to switch panels. If not, could there be a custom panel that allows selecting which fields from any other panel?
Kevin
Re: Label and Describe?
Post by Hert » 08 Jul 20 15:15
You can add custom fields in the Info panel.
You can also use the All or Categories section, then keep the Details panel open and assign labels by drag/drop the thumbs to the label on the left side.
LifeIsLong
Post by LifeIsLong » 09 Jul 20 11:10
Sorry, I should not have used the word "fields"... what I meant is that I would like to be able to either add the description edit box to the labels panel, or the labels assignment "panel" to the details panel. Or, have a custom panel that allows me to add those gui elements to it.
using the categories with drag-and-drop is something I hadn't thought about... I'll have to look at that as a work-around.
Thanks!
